It is currently Mon Jul 21, 2025 7:34 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 12, 2008 10:45 pm
Colin, are your sides the same width all the way around? If not, how do you handle moving the lining down the sides in the upper bout while going around them?
Craig, it looks like you are using kerfed linings with a thin cap on them. Is an accurate description?
PostPosted: Thu Mar 13, 2008 3:18 am
Yes , that's basically it Lillian, except that the kerfed part isn't wedge shape. It also has a rebate to accept the capping for a flush fit.
Cheers , Craig Lawrence
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Thu Mar 13, 2008 3:19 am
PostPosted: Thu Mar 13, 2008 6:21 am
I use a normal 15' back and 25' top. Pre-profile the back before bending, and install the linings as normal. Then sand in the dishes.
PostPosted: Thu Mar 13, 2008 5:41 pm
TonyFrancis wrote:
I wish wish wish I could buy my linings. But since I build reproductions of old Weissenborns, which feature funky shop made linings, I have to make them the same way also to get the look but also lighter weight because of the smaller body size than a regular acoustic.
Who is the man to call if you want funky custom made linings out of a specific material?
I use those same funky linings on my ladder braced guitars and have to make them myself, but I'll not be making yours since It's not my favorite thing either. I usually just suffer thru making as many as I can tolerate so I don;t have to do it too often.
PostPosted: Thu Mar 13, 2008 9:54 pm
Thanks guys.
PostPosted: Fri Mar 14, 2008 2:33 am
First name: Josh
Last Name: French
City: Houston
I use the same method as Colin (got the idea from him!) and will never go back to anything else, unless I'm doing a very accurate replica or something. The laminated solid linings are my favorite of anything i've tried.
Instagram: @jfrenchluthier
PostPosted: Fri Mar 14, 2008 8:44 pm
Don't you have a funky adjustable jig so you just shoot your plane across the top of these?
I really need a jig so I can do this.
Users browsing this forum: George L and 27 guests
